Ahhh need help plz!
Old Nov 8, 2005 | 08:23 PM
nascarpunk15's Avatar
nascarpunk15
Default Ahhh need help plz!
Well i have a ford ranger with an 86 mustang 5.0 HO. i drained the gas tank and replaced the fuel pump. now it dosent idle and not run no matter what timing i give it. you have the feather the throttle just to keep it barely running and you still cant get it over 3,000 rpm. i have replaced the coil, cap, plugs, rotor, wires, fuel pump, and the fuel filter. I think it is the computer that is bad. if you have had a problem similar plz help me out.
Old Nov 8, 2005 | 09:04 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Ahhh need help plz!
that is way too broad to answer. if it fires, you have either a spark or fuel issue.
w/ out putting a guage on it to check fp, you can't know, thats the easiest to eliminate , then go from there
getnmineinmay
Apr 6, 2005 12:15 PM
ballzoutstang875.0
Mar 30, 2005 09:51 PM
supertrooper4
SVT Forums
Sep 18, 2004 03:24 PM
mustang_2004_65
Oct 21, 2003 11:18 PM
