Resetting the computer without disconnecting battery
Old Nov 8, 2005 | 09:40 PM
megabyte1024's Avatar
megabyte1024
Default Resetting the computer without disconnecting battery
My negative battery cable just refuses to come off. I want to reset the computer because of certain check engine light problems I am working on. I was wondering if pulling the fuse was a good idea? Will it reset the computer? There are a bunch of fuses in the fuse box under the hood. Which one of these? TIA.
Old Nov 8, 2005 | 09:52 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Resetting the computer without disconnecting battery
I would just work at getting the battery cable off. Your gonna need to some time.
Old Nov 8, 2005 | 10:01 PM
stanglx2002's Avatar
stanglx2002
take a flat tip screwdriver and move it back and forth to pull the clamp apart more
Old Nov 8, 2005 | 11:20 PM
MustangChris04's Avatar
MustangChris04
get some wd40 or something similiar and take it off. Its always to have a good connection to your battery.
Old Nov 9, 2005 | 01:32 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Or just disconnect the positve terminal or disconnect the neg at the chassis.
Old Nov 9, 2005 | 04:05 PM
03YellowPony's Avatar
03YellowPony
With OBDll systems, you can disconnect the battery as much as you want, and it will NOT reset any MIL stored in the ECU. You need a code reader for that.
Old Nov 9, 2005 | 04:41 PM
waxyourboard's Avatar
waxyourboard
Hm, won't wd-40 light on fire? maybe possibly? just wonderin
Old Nov 9, 2005 | 05:16 PM
JD1969's Avatar
JD1969
ORIGINAL: 03YellowPony
Good point Yellow, but he never did say what year his car was or even what engine he is working on.
Old Nov 9, 2005 | 06:51 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: waxyourboard
It is flammable but I spray it on battery terminals all the time. you won't have a problem with fire and it's good for getting rid of any corrosion you might have on there.
Old Nov 9, 2005 | 11:15 PM
shane361's Avatar
shane361
You can disconnect the pos and the neg and touch them together and that will clear the entire PC. Good for those time you take the car into the dealership. They can read readlines and much more stuff-Shane
