Problems with my Rev Limiter or not?
Old Nov 16, 2005 | 12:19 AM
FOX_MagiCDragoN's Avatar
FOX_MagiCDragoN
Default Problems with my Rev Limiter or not?
Hey, what's up all.
This is my first post here on these forums as I'm a newly registered member. I may or may not have a problem with my Mustang so I decided to come here and create a post so that I can recieve feedback from those who are most familier with my car. Well, enough jibber jabber, here's the deal.
My Car:
2001, Convertible, v6, Automatic, Mustang.
Problem:
When I rev my car, the rev limiter kick in at 4,000RPMs while the car is in Neutral which, from memory, never happened before. When I keep the car in first gear it revs past the redline which is at about 5,250RPMs or more. In fact, I've never hit the rev limiter while the car was in gear and have no idea where the rev limiter sits. I'm pretty sure I've past the redline while the car was in neutral before. Although the Check Engine light is not on, should I take it in to find a possible code # given from the computer or is my Mustang acting as it should?
Old Nov 16, 2005 | 12:24 AM
downwardspiral's Avatar
downwardspiral
Default RE: Problems with my Rev Limiter or not?
alot of cars have a rev limiter for park or neutral set much lower. I guess they put it in so you dont blow your engine while sitting still. someone else more knowlegable on the subject will correct me, but thats all i know.
Old Nov 16, 2005 | 12:33 AM
FOX_MagiCDragoN
I could have sworn I've hit the redline before while in neutral but I just can't put my word on it. I can't recall actually hitting it. But I do recall reving my engine while in neutral plenty of times and you would think that I would have easily hit 4,000RPMs and I would have noticed this sooner. So I guess I need someone who has a Mustang around the 01 model to reply or just someone who knows the answer in general.
**Edit**
Well, after searching the forums some more and talking to my friends, I believe what you were refering to is called a Standing Rev Limiter. Now the question is, does my 01 v6 Mustang have a Standing Rev Limiter? So now I'm pretty confident that their's nothing wrong with my car, but it would be nice to have someone to verify this. Also, where does my Rev Limiter sit while it's in gear?
**End Edit**
Old Nov 16, 2005 | 08:52 AM
garygreen211's Avatar
garygreen211
I ♥ Acer
My 01 GT does not have a standing rev limiter.
Old Nov 16, 2005 | 11:15 AM
gt96stang's Avatar
gt96stang
But he doesnt have a GT, he's got a v6.
Old Nov 16, 2005 | 04:50 PM
03YellowPony's Avatar
03YellowPony
The V6 does have a standing rev limiter. And the load rev limiter is set at redline stock. You can change both with a flash tuner. I have the DiabloSport and I set my park/neutral limit at 5000 RPM, and in gear it's set at 6250 RPM. Kinda strange tho, before I got the Diablo, I went over 6000RPM drag racing once...And I still can't go over about 4800 RPM in neutral...
jma2
Jul 10, 2023 01:00 AM
Nick Oliver
Oct 17, 2018 04:22 AM
JoshyGT
Sep 19, 2017 08:52 PM
uberstang1
Sep 20, 2015 06:42 PM
