currie 9inch rear end?
Old Nov 19, 2005 | 01:34 AM
iburyshoes's Avatar
iburyshoes
Default currie 9inch rear end?
does anyone use this rear end kit? it's a 9inch 31 spline rear available from summit. Is it on par with the ford rear? It's a little cheaper than the ford, and i'm a little over my budget. Thanks for your help.
Old Nov 20, 2005 | 12:09 AM
tinman's Avatar
tinman
Default RE: currie 9inch rear end?
Unless you are making a whole bunch power and using a real big tire and drag with a manual trans don't fool with the 9".
The 8.8 can be built whole lot cheaper and can take lots of power thru it.....
Old Nov 20, 2005 | 08:07 PM
iburyshoes's Avatar
iburyshoes
thanks for the tip.
i'm hoping to make about 750hp through a manual trans when everything's done. Should I still stick with the 8.8? Durability is a major concern.
Old Nov 20, 2005 | 11:24 PM
downwardspiral's Avatar
downwardspiral
ORIGINAL: tinman
Why not a 9"? its the best rear out there. Its easier to work on than an 8.8, stronger and the parts are about the same price.
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
