vibration
Old Nov 19, 2005 | 02:13 AM
re1080's Avatar
re1080
Default vibration
i have a nasty vibration that only happens when i accelerate hard. it shakes the bottom of the seat and the shift **** real bad. any help is greatly appreciated
Old Nov 19, 2005 | 02:55 AM
smoker40's Avatar
smoker40
Default RE: vibration
sounds like a ujoint to me
Old Nov 19, 2005 | 03:04 AM
kartracer55's Avatar
kartracer55
how olds the car/ how many miles?
Old Nov 19, 2005 | 03:28 AM
03YellowPony's Avatar
03YellowPony
Yea, either a u-joint, or the drive shaft may be out of balance. Grab the drive shaft just behind the tranny, and try to move it. Go up, down and side to dide. If it moves ANY little bit, bad u-joint.
EDIT....
Then repeat at the other end of the shaft, near the dif.
If one is bad, replace both.
Old Nov 19, 2005 | 12:04 PM
re1080's Avatar
re1080
its a 1990 with 104k on it and thanks for the replies
Old Nov 20, 2005 | 08:46 PM
sprostang's Avatar
sprostang
I ♥ Acer
Yeah, probably a ujoint. But also check your trans mounts. I had a Z28 that did the same thing while hard acceleration as well and it was the trans mount.
Old Nov 21, 2005 | 12:02 AM
kartracer55
ORIGINAL: sprostang
My neighboors truck does that too, but he doesnt know **** about anyhting mechanical so itll never get fixed.
Jim
Old Nov 21, 2005 | 02:36 AM
sandcracker21's Avatar
sandcracker21
ORIGINAL: sprostang
if its the mount then the car should shake all the time, not just at accel
Old Nov 21, 2005 | 07:54 PM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: sandcracker21
ORIGINAL: sprostang
Nah, not with mine. When I was crusing speed it was fine. When I accelerated, thats when the shakeing began.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
