93 cobra motor?
Old Nov 25, 2005 | 01:23 AM
blackstang89's Avatar
blackstang89
Default 93 cobra motor?
I just purchased an 89 GT claiming to have a 93 Cobra motor in it. It clearly has a Cobra intake manifold, but I don't know how to tell if the rest of the motor is truly a cobra motor. Are there any clear differences to identify without having to run serial numbers on the heads etc.? If so (about the serial numbers) where do I find these and what numbers would I be looking for?
Old Nov 25, 2005 | 03:25 PM
Tim37's Avatar
Tim37
Default RE: 93 cobra motor identification
the head casting #'s will tell you a lot cobras also had underdrive pullies form the factory along with diffent computers. the easiest thing might be to putt the ecu and check the numbers on it.
Old Nov 25, 2005 | 04:21 PM
blackstang89
I don't know if the ecu was also transplanted with the motor or if the stock 89 ft ecu is still intact. Also I don't wouldn't how to discern between the two ecu's. What are the visual differences? What number on the head casting would I be looking for?
firehorse02
Nov 16, 2015 11:28 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
