Seafoam
Old Dec 8, 2005 | 12:18 PM
Vash the Stampede's Avatar
Vash the Stampede
Default RE: Seafoam
i did it before on a 5.0 just pull the line off the break booster, and keep your fingur on it so it won't die out and slowly let it suck in like half a can of seafoam.
Old Dec 8, 2005 | 12:49 PM
M1ke's Avatar
M1ke
Default RE: Seafoam
you wont get the huge smoke cloud coming out till you put it into the cumbustion chamber i.e. through the brake booster line
Old Dec 8, 2005 | 02:06 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: Seafoam
ORIGINAL: AMC
ORIGINAL: M1ke
ok that helps a LOT............ where would you put it in at exactly?
[:-] You know the little cap that you open to put the oil in the engine, the thing that goes vroom vroon? Well twist that counter-clockwise untill it comes off. Place it some where safe and secure so you dont loose it.
K got that?
Pour a third (1/3) 33.33333% of it into that hole. Find that cap you put somewhere and screw it counter-clockwise back on mmmk.
Step #1 done. Pat yourself on the back.
Now. Find the Master cylinder.(the thingymabob that makes you stop) Go behind it and you will find this large round hockeypuck like thing. Now that is called a brake booster. Aid's in stopping your car. From that you will find a hose going from the brake booster (hockey puck thing) to your intake manifold. (the thingy ontop of your engine block) Pull the hose From the brake booster (puck) and pour a third (1/3) 33.33333% into the hose. Re-attach the hose to the
booster.
Congradualtions, your almost there...Now here is the tricky part.
Find the gas cap. Should be Somewhere on the rear quarterpannel. Tricky son of a bitch to find. Usually here.
Now...if you can. Add the last 1/3rd 33.3334% to it.
Yay!
Let sit for 15 minutes and start. Run Untill the smoke stops pouring out of the back. Change your oil and enjoy.
BWAHAHAHAHAHAHAHA [sm=icon_rofl.gif]
Old Dec 8, 2005 | 06:06 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
Default RE: Seafoam
if only all our posts were equally as funny and as informative as that one.
Old Dec 8, 2005 | 07:04 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: Seafoam
i agree, what was funny as all hell [sm=icon_cheers.gif]
Old Dec 10, 2005 | 04:30 PM
M1ke's Avatar
M1ke
Default RE: Seafoam
i actually looked for the brake booster today and there is no hockey puck looking thing near my brake master cylinder. btw i have a 96 gt. i saw on the cobra forums they used the pcv hose. could this work?
Old Dec 10, 2005 | 04:40 PM
BraMas's Avatar
BraMas
Default RE: Seafoam
Yes that is where you would put it in.
Old Dec 12, 2005 | 01:04 AM
95stang5.0's Avatar
95stang5.0
Default RE: Seafoam
how expensive is this stuff??? and should i do it to my 95
Old Dec 12, 2005 | 05:47 PM
5.0family's Avatar
5.0family
Default RE: Seafoam
yes howm uch and where do i buy
oh and that post was priceless
Old Dec 12, 2005 | 08:53 PM
Vash the Stampede
Default RE: Seafoam
its 5bux at advance or autozone, i do it every 6k miles or so. i just put it in the gas tank. a half a can. and then half a can in the break booster.
