Seafoam
Old Nov 28, 2005 | 02:50 PM
91hatchb's Avatar
91hatchb
Default Seafoam
Id been reading from a number of ppl that seafoam works to help ur car run better so i broke down and bought some today. Sucked up a can through a vacum line then let it stall out and let it sit for about 30mins. Started it back up and had one hell of a smoke show lol. Drove it down the street for about 10mins and let the smoke clear lol. Well i noticed a few things it made cold starting easier and it idles a hell of alot better. Kinda pricy but for the results the stuff works really good
Old Nov 28, 2005 | 03:50 PM
M1ke's Avatar
M1ke
Default RE: Seafoam
im asuming you have a 91 hatch?? did it take you a while for it all to get sucked up? which hose/where would you put it in on a 96? gt
Old Nov 28, 2005 | 07:21 PM
AMC's Avatar
AMC
Default RE: Seafoam
1/3 of a bottle on the camshaft/crank. 1/3 in the brake vaccume line, 1/3 in the gas tank. Be sure to change your oil after.
Old Nov 28, 2005 | 10:25 PM
M1ke's Avatar
M1ke
Default RE: Seafoam
ok that helps a LOT............ where would you put it in at exactly?
Old Nov 28, 2005 | 11:47 PM
AMC's Avatar
AMC
Default RE: Seafoam
ORIGINAL: M1ke
[:-] You know the little cap that you open to put the oil in the engine, the thing that goes vroom vroon? Well twist that counter-clockwise untill it comes off. Place it some where safe and secure so you dont loose it.
K got that?
Pour a third (1/3) 33.33333% of it into that hole. Find that cap you put somewhere and screw it counter-clockwise back on mmmk.
Step #1 done. Pat yourself on the back.
Now. Find the Master cylinder.(the thingymabob that makes you stop) Go behind it and you will find this large round hockeypuck like thing. Now that is called a brake booster. Aid's in stopping your car. From that you will find a hose going from the brake booster (hockey puck thing) to your intake manifold. (the thingy ontop of your engine block) Pull the hose From the brake booster (puck) and pour a third (1/3) 33.33333% into the hose. Re-attach the hose to the
booster.
Congradualtions, your almost there...Now here is the tricky part.
Find the gas cap. Should be Somewhere on the rear quarterpannel. Tricky son of a bitch to find. Usually here.
Now...if you can. Add the last 1/3rd 33.3334% to it.
Yay!
Let sit for 15 minutes and start. Run Untill the smoke stops pouring out of the back. Change your oil and enjoy.
Old Nov 29, 2005 | 12:14 AM
M1ke's Avatar
M1ke
Default RE: Seafoam
way to be a jackass about it. ive done it before to a honda which is totally different to a mustang and the hose to suck it up wont be in the same place. maybe its possible that at least one person in the world doesnt know where the right hose is to suck it up.
Old Nov 29, 2005 | 02:08 AM
waxyourboard's Avatar
waxyourboard
Default RE: Seafoam
Technically, i thought that was pretty comprehensive. I thought the picture was a nice touch. Only my gas cap doesnt have a smiley face on it.... must be a special option from the factory.
Old Nov 29, 2005 | 02:25 AM
fordguy17's Avatar
fordguy17
Default RE: Seafoam
ORIGINAL: AMC
ORIGINAL: M1ke
K got that?
booster.
Yay!
loosen up M1ke- he was just messing around. besides that was actaully a very good, detailed post.
Old Nov 29, 2005 | 06:26 PM
M1ke's Avatar
M1ke
Default RE: Seafoam
yeah i know. it was a good post, i now know where the brake booster and hose is,i just didnt care for all the **** acting like i was stupid
Old Dec 8, 2005 | 03:19 AM
98stang6's Avatar
98stang6
Default RE: Seafoam
yeah i bought a can of seafoam cuz i saw a vid somewhere of carbon shootin out hte tailpips n how good it was. I put a third in my pcv valve instead of the brake booster (it said those were your choices on the can itself) and waied 5 min then fired it up n nothing happened. i put another third in the tank n have a third left. so do u have to use a whole can on the car at a time. 1/3 in brake booster. 1/3 in oil. and 1/3 in fuel tank, to make the carbon sh it shoot out? and u said wait 15 min to 30 min? i guess ill buy a new can n try again. thanks guys
