A strange whinning
Old Dec 2, 2005 | 06:56 PM
Scjar's Avatar
Scjar
Default A strange whinning
When I drive my '99 Mustang GT I hear a whinning coming from the front end, more on the drivers side. Its a 5-speed incase it has anything to do with the tranny. The whine is worse as the RPMs get higher and sometimes when I push the clutch in, it stops, sometimes it doesn't. It even has a slight whine when its idle. Some drives don't have much whine at all, but others are embarassingly awful. What could it be?
Old Dec 2, 2005 | 06:59 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: A strange whinning
Sounds like a throw-out bearing on it's way out.
My TOB started with a whine and eventually it progressed into a an extremely high-pitched sound.
Old Dec 2, 2005 | 07:03 PM
angcobra's Avatar
angcobra
Does sound like the TOB.
Old Dec 2, 2005 | 07:22 PM
Scjar's Avatar
Scjar
Ah, thats what I was thinking as well, but Im no car expert so I wanted to make sure. Thanks for the help
Old Dec 2, 2005 | 07:24 PM
angcobra's Avatar
angcobra
The key to your information, is the noise changing when you depress the clutch. Your TOB is always turning when the engine is running, you change how much load is on the bearing when you depress the clutch.
ORIGINAL: Scjar
Old Dec 2, 2005 | 07:39 PM
StickShifty's Avatar
StickShifty
it is 100% your To bearing. mine does that at idle and gets higher pitched as you rev it up. when you throw in the clutch it instantly stops. sounds just like a blower.
Old Dec 2, 2005 | 09:13 PM
Scjar's Avatar
Scjar
About how much does it cost to get it fixed?
Old Dec 2, 2005 | 09:19 PM
waxyourboard's Avatar
waxyourboard
Yep. Definitely your supercharger.
Old Dec 3, 2005 | 02:54 AM
mustang_montana's Avatar
mustang_montana
you might wanna get a whole new clutch kit, thats the best way to doit. the tob is easy to get to though if you are pressed for time/money. tob are failry cheap too, but still id just get a clutch kit for like 200$ or so and either replace or resurface your flywheel.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MustangVixenGT
Sep 16, 2015 04:16 PM
Emblazoned
Sep 3, 2015 10:45 PM
