HYDRO LOCK QUESTION....
Old Dec 4, 2005 | 11:08 PM
cagedthought's Avatar
cagedthought
Default HYDRO LOCK QUESTION....
I have a 2001 mustang 3.8 V6 and drove through a puddle that i didn't expect to be as deep and ended up getting stuck. Anyhow the car died and didn't start. I pulled all of the spark plugs, started the car and pump all of the water that was left. I let it dry popped the plugs back in. Drained the oil and filled it back up. I then started the car and it's making a knocking sound. Can someone tell me what's wrong? Did I blow a piston? or piston rod? If that were the case then the car wouldn't even start correct? Any help would be greatly appreciated.
Caged thought
Old Dec 5, 2005 | 12:00 AM
Vash the Stampede's Avatar
Vash the Stampede
Default RE: HYDRO LOCK QUESTION....
holy cow... wait a minute a puddle?!
that has to be one deep puddle because your intake is prety freaken far from the ground i doubt that it actually hydrolocked.... unless your car has a vortech supercharger. because on a V6 the location of the filter is actually behind the fog light. and thats prety low to the ground. (on a Vortec that is)
Old Dec 5, 2005 | 12:12 AM
cagedthought
ok it was more like a mini lake lol maybe 2 feet or so. Any recommendations that you can offer to help?
Old Dec 5, 2005 | 12:15 AM
Vash the Stampede
2 feet? ehhhh, the the stock filter and the cold air intake location is just right out side of the engine bay in the fender. IT should still be prety tough for water to get in there.. BUT if you look right under your car.. you can actually see your filter from under it...
generally when you hydro lock your engine its toast... but you said its KNOCKing. gas maybe? low octane gas ususaly creates knocking noises.. but iam still not sure on how it would get IN the gas.. but its a long shot...
if it comes down to you needing a new engine.. ebay has 3.8 engines for like 600 bux.
Old Dec 5, 2005 | 12:18 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
probably messed on of the rod bearings up!
Old Dec 5, 2005 | 12:45 AM
dan's Avatar
dan
ORIGINAL: Vash the Stampede
so buying full exhaust would be 2 times the cost of buying a whole new engine [:@]... i hate to think about things that way, it makes me feel like im wasting my money.
Old Dec 5, 2005 | 03:27 AM
Vash the Stampede
ORIGINAL: dan
i mean seriously.. haha its not like hes getting a 32 valve cobra engine... i was just saying if it has to come down to that extreme and him needing to replace it.
Old Dec 5, 2005 | 03:53 AM
cagedthought
I know it's going to cost some money. A friend of mine assumes it might me a blown valve if that's the case how much do they run? and with labor? Also what might you think also be the problem?
JAmes
Old Dec 5, 2005 | 08:17 PM
cagedthought
bump
Old Dec 6, 2005 | 03:31 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: cagedthought
bump
How long did it run under water? and how much water was in the cylinders? If it ran for more than a few seconds with water in the cylinders, it's toast. Water doesn't compress very Well. You could do a compression test to see if you may have bent a valve or cracked a piston. But my money says you will need a new set of heads at the very least. More like a new engine. Now would be the time to put a 4.2 stroker from supersixmotorsports in. Go with the stage 3!!
BOB ROME
Jul 26, 2023 01:54 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
guitarman376
Sep 30, 2015 05:54 PM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 06:58 PM
