clutch cable
Old Dec 10, 2005 | 01:39 AM
Richfiero's Avatar
Richfiero
Default clutch cable
Is possible that the heat from a header could cause the clutch cable to stretch making it almost in possible to get into gears?
Old Dec 10, 2005 | 02:18 AM
Birdieman4's Avatar
Birdieman4
Default RE: clutch cable
Ok, first things first. What year is your mustang?
Old Dec 10, 2005 | 03:40 AM
nitrous_bob's Avatar
nitrous_bob
not stretch, but cause the plastic to bind on the cable for sure...especially if you have long tubes.
stock headers..highly doubtful.
Old Dec 10, 2005 | 04:46 AM
Richfiero's Avatar
Richfiero
its a 1992 5.0 and its has shorty mac headers. I have to push the clutch all the way to the floor and When its running its very hard to shift in to gears
Old Dec 10, 2005 | 02:52 PM
nitrous_bob
it's not disengaging all the way.
do you feel it bind in the cable at all? i would replace it quick. it could toast your clutch, since when your shifting...it's slipping.
is it an adj. cable? look under the dash and see if the quadrant is plastic or aluminum. or if you already know for sure.
if it's the stock plastic, get an adjustable too. you can also get a length of "fyr-sleeve" to go over the cable itself, will help protect the cable a little better...will still burn through though eventually.
EDIT***************if it is adjustable...try adjusting it first. (not sure if you have, or pull up on the clutch pedal hard...if it's stock)
Old Dec 10, 2005 | 05:20 PM
Richfiero's Avatar
Richfiero
I havent looked at it yet my friend that i bought it from said it was the clutch cable. but i will try and adjust it or get a new and see if that works.
Old Dec 10, 2005 | 06:57 PM
Richfiero's Avatar
Richfiero
well the cable seems to be very loose so I'm goig to try and replace it.
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
junior04
Sep 28, 2015 10:53 AM
