it stalls sometimes
Old Dec 12, 2005 | 11:24 AM
doc_phibz's Avatar
doc_phibz
Default it stalls sometimes
i have a 95 gt, with mods. sometimes(not often) i'll be driving and when i put my foot on the clutch or to coast it will stall out, if i rev the engine in time then it won't stall, and not give me any prob. for a while. i see it's bout to stall b/c the tach will drop past 700 rpm(of course), and when it drops, it drops fast( no kind of bouncing effect when at idle on the tach). could it be the comp. an ignition prob., or fuel delivery prob.? the spark plugs are new, the dist. cap and rotor are new. i have a f-303 cam( if that may have something to do with it since it has a rough idle). i keep it maintained with lucas fuel treatment and engine lube to keep the fuel lines clean. hope i gave enough info, thanks for all your replies.
Old Dec 12, 2005 | 12:24 PM
Tim37's Avatar
Tim37
Default RE: it stalls sometimes
ya just need to idle it up a little. there shoud be an adjustment screw on the throttle body.
Old Dec 12, 2005 | 02:13 PM
pj1010's Avatar
pj1010
Maybe his IAC is crapping out.
Old Dec 12, 2005 | 03:41 PM
Dan04COBRA's Avatar
Dan04COBRA
Sure sounds like IAC
Old Dec 12, 2005 | 05:43 PM
doc_phibz's Avatar
doc_phibz
thanx. do i need to take the throttle body out to do it? or can i just unblot it off the tb?
Old Dec 12, 2005 | 11:38 PM
Car_Ramrod's Avatar
Car_Ramrod
sticky in the 4.6 section
Old Dec 12, 2005 | 11:46 PM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: doc_phibz
You can just unbolt it, spray it with carb/fuel injector cleaner to clean it and it should be ok.
Old Dec 13, 2005 | 11:53 AM
doc_phibz's Avatar
doc_phibz
thanks to all you guys, i appreciate your help. and is there any aftermarktet companies that makes these, if i choose not to clean it? if so would it help hp or mileage
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
trashxtrash
Sep 20, 2015 10:49 PM
