Shocks/Struts question...
Old Dec 19, 2005 | 04:44 AM
dawssvt's Avatar
dawssvt
Default Shocks/Struts question...
I have a set of Eibach Sportline springs on my 98 Cobra right now and my car is pretty rough. I am not looking to do much more drag racing or Auto-X or anything like that in the near future. I just want my ride to be better. What shocks/struts will be the best just to smooth out my ride?
I have heard very good things about the Bilstein Heavy Duty Shocks/Struts, but I don't know if they are good for racing or good on the ride... I have also heard good things about the TOKICO shocks/struts. I am not needing them for race, so is the adjustable really necessary?
Bottom line.... I JUST WANT MY CAR TO RIDE BETTER!!!!!!!!! I will spend the money I need to for it to ride close to stock and look the way it is now! PLEASE HELP!!!!!!!!!
Old Dec 19, 2005 | 12:33 PM
Tim37's Avatar
Tim37
Default RE: Shocks/Struts question...
struts won't help the ride that much if at all most of the time they make the ride worse. if i where you i would look in to gettting a diffent set of springs that had a lighter spring rate.
Old Dec 19, 2005 | 04:24 PM
sandcracker21's Avatar
sandcracker21
the bilsteins are amazing, my buddy has them in his beemer, and the difference was amazing,
pricy tho
Old Dec 19, 2005 | 04:28 PM
codyss's Avatar
codyss
Bilstein shocks/struts will add to the hard ride not help.
Old Dec 19, 2005 | 04:57 PM
dawssvt's Avatar
dawssvt
how could it make it worse? I dont understand that?
Old Dec 19, 2005 | 07:54 PM
codyss's Avatar
codyss
The HD Bilstein shocks/struts have a very hard compression and quick rebound.
If you want a smooth ride with high rate springs you need shocks/struts with a soft compression and a slow rebound.
Old Dec 19, 2005 | 07:59 PM
Tim37's Avatar
Tim37
wow for once codyss is making sence.
basicaly the shocks and struts only alow the springs to compress at a certian rate of speed. so you best bet is just stay with your worn out struts or get new springs for rid. get a set of drag springs that will lower your car they will giver you the nice ride you want.
Old Dec 19, 2005 | 08:17 PM
dawssvt's Avatar
dawssvt
which springs would you suggest?
Old Dec 20, 2005 | 12:17 AM
BlackSN95's Avatar
BlackSN95
When I lowered my stang,(Eibach pro-kit), I installed some Tokico illuminas. They have 5 adjustable settings, so it rides as soft or as firm as you want it. They cost about $450 a set on ebay
Old Dec 20, 2005 | 05:30 AM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: BlackSN95
+1, cept i have the Steeda sport springs, also a good ride, but not as low as ur sportlines...
