need advice
Old Dec 19, 2005 | 09:06 PM
302pony's Avatar
302pony
Default need advice
hi i was woundering is it ok to re use roller lifters from the junk yard. thanks mike
Old Dec 19, 2005 | 09:10 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: need advice
It might be if they are in good shape< but I do NOT think it is a good idea. Think about it for minute, cheaping out now on somthing realitivly cheap could cause a lobe to be wiped out on the cam, and possibly cause more damage.
Old Dec 20, 2005 | 08:34 AM
302pony's Avatar
302pony
thanks for the info
Old Dec 20, 2005 | 10:44 AM
Chopper's Avatar
Chopper
Even if they have fairly low mileage used lifters of any kind have wear patterns permanently ground into them.If you try to match them with a new cam both parts will quickly fail.Even changing lifters from hole to hole in the same engine will have the same result.
Old Dec 21, 2005 | 01:30 AM
OnyxCobra's Avatar
OnyxCobra
id say never reuse old lifters unless ur using the cam they were with and know the correct lobes for each lifter.
Old Dec 21, 2005 | 01:00 PM
Tim37's Avatar
Tim37
i wouldnt go to a junk yard to get rollor lifters but i have seen people reuse them in cars many times with absolutly no problems.
Old Dec 21, 2005 | 05:05 PM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: Tim37
is this with a new cam?
Old Dec 21, 2005 | 05:37 PM
Tim37's Avatar
Tim37
ORIGINAL: OnyxCobra
ORIGINAL: Tim37
yeah i know a guy that has had at least three diffent cams with the same rollor lifters. now a normal flat tappet reuse is a big no no. but you can get buy with it on a rollor but i still wouldn't go out to a junk yard and get them. ya never know a lifter problem could be the reason the car is in the junk yard.
Old Dec 21, 2005 | 07:53 PM
OnyxCobra's Avatar
OnyxCobra
hmmm, ive heard you should really change ur lifters even on a roller cam when u get a new cam
Old Dec 23, 2005 | 06:59 AM
3drgenracer's Avatar
3drgenracer
i wouldnt roller lifters are not that expensive. and if you dont have the money i think it would be woth the wait to get new ones in case you would mess something up then you could be out big money.
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
