horsepower
Old Dec 26, 2005 | 05:20 PM
01musgt's Avatar
01musgt
Default horsepower
i have a 01 mustang gt with super 40 flowmaster exhaust, k&n fipk kit, hypertech programmer
how much horse power to the wheel am i putting out, my fastest time at the tracks is 14.45
i have about $ 250, what should i buy first to drop my et (cheapest horsepower) or should i just save for rear gears
Old Dec 26, 2005 | 05:21 PM
Tim37's Avatar
Tim37
Default RE: horsepower
i would guess about 250 maybe. i would look at some pullies or a throttlebody and upper intake.
Old Dec 26, 2005 | 05:35 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
About 10-30 RWHP more that stock would be my guess.
Old Dec 26, 2005 | 06:13 PM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
about 245rwhp... get the gears. 3.73 if 5spd ... 4.10 if auto
Old Dec 26, 2005 | 07:18 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: 01musgt
The best mod to drop your ET would be a set of drag radials. They will help a little now and a lot later on down the road.
mkspeed26's Avatar
mkspeed26
definately save 4 gears
Old Dec 26, 2005 | 09:41 PM
sandcracker21's Avatar
sandcracker21
i would save for gears or as JD1969 said, DRs,
a good set of tires will let u launch the car and use its true potential
Old Dec 27, 2005 | 03:36 PM
Deannostang's Avatar
Deannostang
Gears, no doubt about it. Single most dramatic change in the cars performance will come from a gear change. I image your year and model would have stock 3.27's. Depending on your tranny and what your main cruising use is, 3.73's or 4.10's would be best. 4.30's just manage to make your first gear (or two) basically worthless and contributes to many replaced tires. 4.30's also tend to put a huge strain on your whole engine over time. You'd definitely need drag tires of somekind with the 4.30's as well. Little or no traction with anything less. Save for the gears.
Old Dec 28, 2005 | 05:57 AM
Rannascar's Avatar
Rannascar
You Probally have about 25 HP added now. With having only $250 get rear end gears. Do not get 3:72 they won't help with out DOT slicks, get 4:10's they will drop the ET into the mid 13's
Jan 6, 2016 07:03 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
Sep 18, 2015 12:25 PM
Other Professional Racing
Sep 10, 2015 11:41 AM
mustangfan305
Aug 7, 2015 11:09 AM
