distributor help please
i have built a 289 kb domes,edelbrock heads, 1.6 roller rockers. 224 dur .512 lift cam,air gap intake street avenger 770 carb, blue brinted and spun balanced. question is i have a msd distributor centrifugol and do not know where timing should be set at and what spring and stops i should use in it. please help
call up the cam company they should be able to help. just aske them if they have a timing recomendation for that cam.
my best guess would be a base about 15 or 16 with 93 octane.(thats if the distrbutor has an advance.)
I've got the same setup. A guy on here told me to run 10 to 12 degrees intial with 38 degrees total. With a hot cam you should be at full timing at around 2200 RPMs. I bought a set of weights and springs and it came with a sheet that had all the timing curves. That should tell you what combo of springs and weights to use to get your timing in by 2200.
bradleyb
Nov 27, 2015 07:50 PM
jaiidutch
Sep 14, 2015 10:29 AM
