shift kit????
Old Dec 28, 2005 | 07:29 PM
delgadog's Avatar
delgadog
Default shift kit????
What is a shift kit? do they even exist and do they make them for Auto's??? what manufacturers make them and can anyone explain how they work and how they will affect the auto tranny?? thanks alot.
Old Dec 28, 2005 | 07:40 PM
marcuslee842's Avatar
marcuslee842
Default RE: shift kit????
The shift kit keeps the line pressure up in an auto tranny to change shifts on the fly ( 1-2 2-1 and D and OD for 4th) They also make the tranny last a little bit longer because of the quicker firmer shifts. It makes the auto way more fun. For something really cool check this out Manumatic TCS system You can change gears (1-4!) on the auto with the cruise control buttons on the steering wheel!
Old Dec 29, 2005 | 04:02 AM
nitrous_bob's Avatar
nitrous_bob
it increases the oiling ability of the trans, and firmire springs for increased points.
they are only for auto's
better oiling = harder shifts (smooth shifts come starving the trans for oil, and shifting dry)
transgo, B&M , many many many companies them
Old Dec 29, 2005 | 05:24 PM
97stanger's Avatar
97stanger
delgadog....i am going to be buying a shift kit this weekend after doing a lot of research on this subject...just to give you some info...
1) a shift kit gives firmer and quicker shifts through an auto tranny, allowing less slippage
2) from what i heard, the best brand to go with is transgo, their shift kits also have different settings where you can set it to different stages, depending how you want the car to shift
3) if getting a shift kit, i would recommend a tranny cooler, nothing big or expensive, but just a cheap tranny cooler to help out
4) good mod...probably good for knocking around .2 off of your 1/4 mile time
any other questions just post up my man
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Explosive
Oct 2, 2015 07:45 AM
