Question....bout fuel injection
Old Jan 1, 2006 | 04:16 PM
Smokinrubber's Avatar
Smokinrubber
Default Question....bout fuel injection
I have a 94 mustang gt and i had a 351w built to 393 ...to replace the 302 what can i use to modify the computer to run the injectors like a 351 ......maybe someone has performed this swap before ..thanx for all replies
Old Jan 3, 2006 | 12:28 AM
Chopper's Avatar
Chopper
Default RE: Question....bout fuel injection
Any chance you can get a 351 computer and have it reburned.Call the handheld tuner companies and see what they can do.If it's been done before I'm sure they can help.
Old Jan 3, 2006 | 02:21 PM
Tim37's Avatar
Tim37
aem makes one of the most versitil computers for your car you can really change things and dos some fine tweeking when it comes to the computer. that a fast engine managment or a pms engine management system is what i would go for.
Old Jan 3, 2006 | 06:45 PM
P.S.I.cho's Avatar
P.S.I.cho
For the most part you dont need much to run the higher injectors, a fuel pump and then a bit of fuel mapping wich can be done through an EMS as tim37 said or even a chip with a good tune
Old Jan 3, 2006 | 11:08 PM
uedlose's Avatar
uedlose
you could just buy set of 30# injectors and get a pro-m mass air that is calibrated for that size injector and for the 94 stang. and go from there.
Old Jan 3, 2006 | 11:09 PM
ByPopularDemand's Avatar
ByPopularDemand
Another question: What happens if a fuel injected car runs out of gas
Old Jan 3, 2006 | 11:27 PM
uedlose's Avatar
uedlose
ORIGINAL: ByPopularDemand
oh,oh,oh,!! I know this one ...........it stops running
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
