Bad Transmission???
Old Jan 1, 2006 | 08:33 PM
dachucksterman's Avatar
dachucksterman
Default Bad Transmission???
I have seen a couple of threads about this problem I am encountering, but have found no apparent answer. I have a '94 V6 3.2L mustang, and I believe it is having transmission problems. I will be driving along, when all of the sudden the RPMs will jump up as if I am in neutral. Then the car will suddenly remember it is supposed to be in gear and slam hard into gear, as if I were neutral dropping. One mechanic told me I might have a broken spring in my piston? That makes no sense to me, but 3 other places i called say it sounds like a transmission problem. It usually does it between 30-40mph, and rarely at higher speeds. It usually does it also after a long trip, usually highway miles. I am not a huge car buff, but I think I understand that AODE is the top gear, is the problem something to do with that?? I hope someone has experienced this before and has a clear cut answer, but any advice or suggestions will be just as helpful. Thankyou,
Charlie
Old Jan 2, 2006 | 12:19 AM
frop's Avatar
frop
Default RE: Bad Transmission???
I'm not too sure, but when you're were told about the piston spring, it's not the engine, it's one of the servos in the transmission he was talking about.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
