351w
Old Jan 2, 2006 | 01:58 AM
benz660r's Avatar
benz660r
Default 351w
Will a 351w fit into a 2002 ford mustang v6 5 speed? If so what kind of adujsutments need to be made?
Old Jan 2, 2006 | 12:29 PM
Tim37's Avatar
Tim37
Default RE: 351w
k member, motor mounts,
then every thing eles you need for the convertion. its not really a easy conversion but can be done you will end up replaceing the entire drive train.
Old Jan 2, 2006 | 07:54 PM
mkspeed26's Avatar
mkspeed26
Default RE: 351w
you would probably have to make some custom headers for it. u may be able to get a new bellhousing so u can keep ur current tranny. driveshaft length will need changing. new motor mounts and k member most likely. oil pan for the engine. most likely a new hood because the 351W is a pretty tall engine. then a new wiring harness
Old Jan 3, 2006 | 12:54 AM
tinman's Avatar
tinman
Default RE: 351w
Hooker has the headers on the shelf. 'Bout $500 or so.
Dunno about the K member but I do know you'll need a hood as the 351W is 'bout 1 1/2" taller and you don't have rrom.......
Old Jan 3, 2006 | 01:26 PM
Tim37's Avatar
Tim37
Default RE: 351w
fox body headers shoudl work just fine yeah you will need a mustang oil pan and all of that i don't see the tranny or rear holding long behind a good 351 thats a lot of torque.
Old Jan 3, 2006 | 06:49 PM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: 351w
you dont really need a new harness for this motor to work, but it is always a good idea to replace the old one anyways
Old Jan 3, 2006 | 07:15 PM
Tim37's Avatar
Tim37
Default RE: 351w
ORIGINAL: moocow_v
um how the hell do ya run the fuel injection on a 351 with a 3.8 harness?
now if you are talking about the body harness no you don't need that at all.
Old Jan 3, 2006 | 10:34 PM
tinman's Avatar
tinman
Default RE: 351w
The 351W Hooker headers are for a Fox body.
You WILL have trouble trying to use 302 headers due to the deck hieght differances.....
Old Jan 4, 2006 | 11:26 AM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: 351w
is this a track car only,,?? you got emmission to worry about ..where im at.....94 and up ther plug into obd plug..??
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
FoxGT
Jul 11, 2004 11:49 PM
Mustang88LXKid
Feb 29, 2004 08:01 PM
WNDSOR
Jan 30, 2004 09:47 AM
