62 mm throttle body
Old Jan 2, 2006 | 10:01 PM
dejr8isgreat's Avatar
dejr8isgreat
Default 62 mm throttle body
I installed a new 62mm throttle body about a week ago. Everything is fine except when I need to make a quick stop in 1st thru 3rd gears, the idle stays at whever it was while in gear for between 8-24 seconds then it drops to around 800. Is this normal, or do I need to do something with the computer. 2005 GT w/K&N air charger, Flowmaster mufflers, and the 62mm throttle body (motoblue cnc billet)
Old Jan 3, 2006 | 06:58 PM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: 62 mm throttle body
the 8-24 second delay isnt normal at all, is it just your tach sticking or can u still hear the motor at full rpm?
Old Jan 3, 2006 | 07:17 PM
Tim37's Avatar
Tim37
make sure that the tps on is on correctly and also check to see if the throttle my be sticking open a little. it should run like it did befor you put the tb on tehre.
Old Jan 3, 2006 | 09:02 PM
dejr8isgreat
It's at full rpm, until it drops gradually in 8-24 seconds. I don't think there is anyway to check to see if it is sticking since its all done by wire into the housing. I have disconnected my battery for 7 minutes as instructed. Should it be longer? Someone told me 7 hours.(the salesman) Everything seems to be hooked up right. It only does this while driving and shifting.
Old Jan 4, 2006 | 03:26 PM
Gaspi101's Avatar
Gaspi101
Don't modern mustangs come with 65mm throttle bodies stock? If so, why did you get a smaller one?
Old Jan 4, 2006 | 08:30 PM
dejr8isgreat
No, stock twin tb on 2005 are alot smaller then twin 62mm I installed, I don't know the actual stock size.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
