Clutch or transmission problem!!!!!!!!!!
Old Jan 9, 2006 | 03:16 PM
edelbrock's Avatar
edelbrock
Default Clutch or transmission problem!!!!!!!!!!
I have a '00 mustang v-6, 5 speed...54'000 miles...lastnight I was at the stop light and i put it into gear and released the clutch but the car wouldnt move....i can actually shift it into all the gears without even putting the clutch in WHILE THE CAR IS RUNNING lol...any ideas? I need to do this a.s.a.p. so any help would be appreciated....fitexcell@aol.com or pm me here....thanks guys![:@]
Old Jan 10, 2006 | 10:17 AM
Djs94stang's Avatar
Djs94stang
Default RE: Clutch or transmission problem!!!!!!!!!!
Could be the clutch is worn although 54K is low for a worn clutch unless it was abused. It sounds like there is no connection between the clutch and engine...either that or the shifter is broken.
Old Jan 10, 2006 | 02:59 PM
pj1010's Avatar
pj1010
Ehh....that's a strange symptom for a clutch to wear out, unless there was previous slipping/notching. I don't think you're clutch would just **** out without warning.
Old Jan 10, 2006 | 06:05 PM
kartracer55's Avatar
kartracer55
Even if the clutch wore out, the car would still want to move. It would seem like the clutch isnt enaging... check the line or cable going to the pressureplate. Im no mechanic though
Jim
Old Jan 11, 2006 | 02:32 AM
edelbrock's Avatar
edelbrock
Basically the pedal has full tension throughout movement when the pedal is pushed. To check for the cable to be bad I would just pull the fork shield right? The shifter is fine. I checked that..thanks guys!
Old Jan 11, 2006 | 06:17 PM
edelbrock's Avatar
edelbrock
Ok guys guess what???? lol i took it apart today and the clutch is toast...i mean there is no clutch plates left...when i dropped the bellhousing nothing but fiberglass and stuff came out...lol so anyways I wanted to thankyou guys for your replies! Thanks!
Pyrate Dave
Sep 10, 2015 07:30 PM
Roush05
Sep 10, 2015 12:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
