pulleys
Old Jan 10, 2006 | 03:11 AM
01musgt's Avatar
01musgt
Default pulleys
i am looking for a set of pulleys and i see the pulley set which constist of the alt,water pump and crank pulleys, then i see a fluid dampened performance pulley from march(says 8 hp gain) where do you install that pulley for a 10 mustang gt
when i change pulleys do i have to change my belt
Old Jan 10, 2006 | 03:36 AM
NewMexMustang's Avatar
NewMexMustang
Default RE: pulleys
you have to change the belt because the pulleys are a different size...the crank pulley is the most important one, the others don't really do much anything powerwise.
Old Jan 10, 2006 | 11:07 AM
gt96stang's Avatar
gt96stang
Default RE: pulleys
Get the steeda kit. Unlike the v6 mustangs, when you change out all three pulleys, it comes out to be the same size as stock. So you will not have to change belts unless you have one that is old and need to replace it anyways. I just changed my belt because it was only 30 bucks for a new one anyways.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
ctgreddy
Sep 20, 2015 08:35 PM
