trnny leaking
Old Jan 10, 2006 | 07:56 PM
jbsr11's Avatar
jbsr11
Default trnny leaking
brought my car to the shop and they said the front and back seals are leaking. in order to change the front they said thet have to drop the tranny. its an 00 auto with 92000k miles. how much should this job cost...includ tranny fluid change and filter?
Old Jan 10, 2006 | 11:40 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: trnny leaking
i'm sure they will want $1200-$1500
whats it worth?? about $500
Old Jan 11, 2006 | 11:26 AM
Chopper's Avatar
Chopper
This is one situation where a trusted shop is worth it's weight in gold.When that shop tells you "the thing needs rebuilt" you can depend on it.Unfortunately,unless you know someone who has dealt with a particular shop,you're going to be pretty much on your own.I don't like the R&R shops,the ones that have a supply of rebuilt trannys.They just remove yours and replace it with a rebuilt unit.Most of the national chains are this type.A local buisness thats been around for awhile is usually the best choice.The one I go to just loves to take you to the rebuild bench and show you all the parts that are TO BE replaced.You get to make the final decision.The point to my long answer is,be careful and don't let them screw you.
Old Jan 11, 2006 | 12:33 PM
Tim37's Avatar
Tim37
have them make sure the rear main seal is good because the trany has to come out for it too it should only add about 20 bucks to the job.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
