drag slicks
Old Jan 15, 2006 | 12:12 AM
1BIGMOFO's Avatar
1BIGMOFO
Default drag slicks
whats the largest diameter slicks i can fit under the rear end of my 94 gt? i want to just get a set of 15's or something with a bad *** set of slicks for wed and sat at the local drag strip
Old Jan 15, 2006 | 02:24 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: drag slicks
There is more to tire selection than just putting the largest diameter that will fit. The taller the tire the higher (numericly lower) your effective gear ratio will be, that and it's added weight which will slow you down. Most slicks come are made for a 15 inch rim. My suggestion is to get a set of Mickey Thompson drag radials that is about the same size as your stock tire, unless you are making a ton (over 400 rwhp) they will hook fine, and might actually give you a better time than the slicks.
Old Jan 15, 2006 | 02:41 AM
Obsol3te's Avatar
Obsol3te
You'll more than likely never need anything larger than a 10.5" "slick"
The MT ET Street 26x10.5x? will take you a long long way.
They DO get a little squirrely around the end of the track, but you can't expect much from a bias ply.
Or you could do as JD said and go with a pair of DR's
You won't have that *** end wobble, and if you're not making a good amount of torque you should be fine off the line.
Old Jan 15, 2006 | 06:59 PM
tinman's Avatar
tinman
I've raced a big block, 3250# on 10.5's with no problem. I ran 10.70's. Ive seen others runas quick as 9.50's.
These are RACE cars. If you don't have a race car do the 26X9 M/T's.......
Old Jan 16, 2006 | 01:00 PM
Tim37's Avatar
Tim37
there are guys out there running 7's on 28 10.5's so i think a set of 10.5's will do you fine.
But like Jd said a set of big slicks can slow you down you do get a lot off the line but what happens is they cause a lot of drag on the top end so after a few foot you won't be ablt to pick up speed as well as on a set of radials.
btw learned this form John Urist if ya runn a over sized wheel like a 11" wheel with 10.5" slicks it will help stabilize it a on the top end. he said ya loose some out of the hole but what you gain with drivability on the top end is worth it.
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 15, 2015 07:34 PM
Dragonus18
Sep 9, 2015 01:21 AM
vintageaion
Sep 8, 2015 10:45 AM
