suspension mods
Old Jan 23, 2004 | 11:26 PM
tstang88's Avatar
tstang88
Default suspension mods
I was just wondering what kind of suspension mods should somebody do to a 88 gt with moderate engine mods and Ill probably be putting in 373 in rear end as well. Any help would be great.
Old Jan 23, 2004 | 11:44 PM
mkspeed26's Avatar
mkspeed26
www.maximummotorsports.com <IMG src=smileys/smiley2.gif border="0"></P>
drag or road race??</P>
Old Jan 23, 2004 | 11:45 PM
jayssilver5.0's Avatar
jayssilver5.0
i would suggest springs and shocks and struts. depending if u want a drag or performance street car determines what kinds........if u wanna take it up a notch.......replace rubber with polyurathane........than get the car braced and you'll be in buisness
Old Jan 23, 2004 | 11:49 PM
mkspeed26's Avatar
mkspeed26
for road race, look into a coil-over kit w/ stiff springs, strut tower brace, subframe connecters, their k-member is SICK!!!!
Old Jan 24, 2004 | 05:25 PM
tstang88's Avatar
tstang88
it would just be for street racing. what about upper and lower control arms and tubular a arms.
Old Jan 24, 2004 | 06:15 PM
n2o44's Avatar
n2o44
on a not so crazy modded car , obvious springs and matched shocks, weakness in the rear is basically the whole set up , the rubber control arms deflect alot , and uppers and the whole design dosent really do its job above stock driving , (which no stang guys does) and the sway bar acts through the lower control arms <IMG src=smileys/smiley11.gif border="0">, cheaply what you need to do it get some aftermarket arms in back , with springs+shocks, at a minimum, panhard, torque arms type stuff and adj sway bars if you want to go all the way . up front springs+struts , control arm bushings , rack bushings, and sway bar end links are minimum, thoses are the worst up front , up from that is coil overs ,a arms ......., </P>
but im assuming your not going nuts , my recomendation s , springs+shocks,rear control arms , chassis stiffing kit, (subs, strut,k memeber braces), and some bushings up front , and yopu will notice a dramatic improvement, </P>
i am also a M+M dealer , if you want stuff from them drop me a mail , good luck </P>
Old Jan 24, 2004 | 06:53 PM
gdear66's Avatar
gdear66
Springs, shocks, and struts</P>
MRT street suspension kit is awesome!</P>
www.mustangracing.com</P>
</P>
Old Jan 26, 2004 | 10:35 AM
KMP5L's Avatar
KMP5L
Depending on you cash flow. I would check out **X**** motorsports. You can get a killer setup from 2,000 to 4,000.</P>
Old Jan 26, 2004 | 06:11 PM
mkspeed26's Avatar
mkspeed26
why do you say ***X****, just say **X****!!
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
