trouble...
Old Jan 19, 2006 | 08:19 PM
DaMustHaveThang's Avatar
DaMustHaveThang
Default trouble...
ive been having trouble with my 1980 mustang(auto), when i turn it on i let warm up for maybe like 5 minutes. then when i put it on drive it lags and doesnt move when i give it gas it feels as though im on neutral all though i am not. after a lil lag and giving it gas it finally moves and since it revs up i end up peeling out when i dont want to. is there anyway i can fix this problem???
Old Jan 19, 2006 | 08:42 PM
marx91's Avatar
marx91
Default RE: trouble...
sounds like your trans is slipping, maybe take it in for a servicing
Old Jan 20, 2006 | 12:43 PM
Chopper's Avatar
Chopper
Check the fluid level.Does this seem to happen mostly when the engine is cold?A low fluid level won't let the pump supply fluid the rest of the tranny and it won't go into gear.If the fluid level is full then the pump might be bad.This means tranny removal and rebuild.[:'(]
CaptainRon
May 29, 2013 09:14 PM
acarzt
Jul 21, 2009 03:28 PM
JMD
Mar 3, 2009 12:34 PM
