car still wont start...PLEASE HELP
RE: car still wont start...PLEASE HELP
ok here is another strange thing that happend.....theres a little plug that comes off the wiring harness right next to the ignition control module.....i think its the little plug that they try to get u to buy on ebay thats supposed to give u HP or somthing.....but anyway i unplugged it and the car started...it idled a little rough...but it ran.....so i shut it off and put it back in and it still started....and ran fine.....so do u think taking this out and starting it reset something??? i just want to know if i fixed it or just happend that way
i think you are talking about the spout connector. it should be a sensor with a little gray chip in it. is this what your talking about. if so..then this is how you set your timing. you unplug that with your motor off. then crank up your car and set your timing. once you timing is set, then you plug it back in. with it unplugged you can set your btdc timing. and when you plug it back in, your computer advances it for you.
ORIGINAL: Idrum88
My 2¢. GL
ORIGINAL: ekthrilla
ORIGINAL: Idrum88
so why do you think my car started when i unplugged it.....when it has not been starting this whole time??? is this all making since to anyone or is it just coincadence?
ORIGINAL: ekthrilla
ORIGINAL: Joel5.0
If you have a connector contact problem or an intermittent wire within the connector, it does make sense. BTSTDTRT(=been there, seen that, done that, repaired that)....had a chance to check the system for codes?. LUK(=Let Us Know)
ORIGINAL: Idrum88
ORIGINAL: ekthrilla
Unless the problem repeats itself,...no need to replace anything (why fix something that is working ok?). It's a possibility though, that only time and use will tell. You might have taken care of the contact problem when you "wiggled" the wires by disconnecting the SPOUT plug, but again, time will tell. Nothing to worry about. If you want to be on the safe side w/out replacing any parts, just do a KOEO self-test after a couple of days of use, if you don't get codes 16 and 18 showing up, no problem to worry about. My 2¢. GL
ORIGINAL: Joel5.0
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
