Tranny Trouble T45
Old Jan 24, 2006 | 05:43 PM
DrUnkEnMaStEr69's Avatar
DrUnkEnMaStEr69
Default Tranny Trouble T45
What was the stock transmission in the 98GT? T-45 right? And who was it made by, Borg-warner or Tremec? Im having transmission trouble and brought it to a shop and the mechanic said i have a tremec T-5...I bought this car used so anything is possible i guess? Any info would be greatly appreciated!!
Old Jan 24, 2006 | 05:55 PM
Tim37's Avatar
Tim37
Default RE: 98GT Stock Transmission??
its a t-45 and i think i remember seeing tremec cast on the side of it.
Old Jan 24, 2006 | 05:59 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: Tim37
+1
Old Jan 24, 2006 | 06:01 PM
codyss's Avatar
codyss
Little off topic but if I remeber right Borg Warner bought Tremec.
Old Jan 24, 2006 | 06:49 PM
DrUnkEnMaStEr69
Default what the emchanic said
when i went to go pickup the car they called the mechanic cause he wasnt in... All i got was he said its definately not a T5..wow...anyways its making not good noises when u push the clutch in and let it out, like almost letting it die, it makes a couple of low thumpung/clanging noises thats ahrd to describe, and he said there is a slight problem witht he 2nd gear synchro. But besides that he dont kno wuts wrong withotu opening it up and I should keep driving with it untill it gets worse and then coem back...uh...what u guys think i should do? get someone to rebuild it and fix wuts wrong, or buy a new tranny? and if so which tranny shud i get?
Old Jan 24, 2006 | 08:01 PM
Tim37's Avatar
Tim37
Default RE: what the emchanic said
once a manual tranny granades it cost a lot more to fix. right now you might get away with new bearings, bushings and syncros. later on you may be replacing gears and other stuff if not the whole thing.
Old Jan 24, 2006 | 08:17 PM
codyss's Avatar
codyss
Mustangs haven't had the T-5 since 1993, The SN95 had the T-45 until mid 2001.
Have you ruled out clutch problems? Or can you deffinately feel/hear it in the transmission?
I wouldn't delay getting it fixed like Tim37 said it will only cost more if you wait.
Old Jan 27, 2006 | 02:02 AM
DrUnkEnMaStEr69
we had it up on the left and it was def coming from the tranny. Its a wierd thign the car does now, like its way easier to stall. I havent stalled since forever, and yesterday i stalled twice!!
Old Jan 27, 2006 | 12:35 PM
Tim37's Avatar
Tim37
it almost sounds like a clutch.
Old Jan 28, 2006 | 08:32 PM
DrUnkEnMaStEr69
thats what i thought but the sound is def coming from in the tranny
CS2007
Jun 25, 2019 09:45 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
