swap compatibility
Old Jan 26, 2006 | 02:06 AM
AJxr's Avatar
AJxr
Default swap compatibility
i have a 98 gt that was totalled beyond repair, the whole drivetrain/engine/harness and everything is fine with only 70k original miles, the car runs and drives, just the chasis is un-usable.
my question is will my motor bolt into a fox style mustang, or anything from 84-92. what wouldn't fit? can i use my whole tranny, drive shaft, rear? do i need an aftermarket mount kit?
ANY HELP WILL BE GREATLY APPRECIATED! Id hate to see all these parts go to waste. I would find another 96-98 style but I love the older mustangs.
Old Jan 26, 2006 | 03:36 AM
alexr's Avatar
alexr
Default RE: swap compatibility
the engine itself will fit with a lot of modification. the 5.0 i believe is bigger, and plus ive seen an sn95 6cyl dropped in a fox stang and have plenty of room left over. as for changing the drivetrain and all that, i dont know if you'd have to or not, sorry.
Old Jan 26, 2006 | 12:28 PM
Tim37's Avatar
Tim37
ok first off a sn95 has the same basic engine bay as a fox every thing will swap right over you may need to also swap the k member too but if you swap all of that it will give you the 5 lug 4 wheel disk brakes.
speaking of brakes that may be one hang up im not sure but you may need to swap out master cyclinders and go with the hydoboost brakes i think that was done for clearance.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
