newbie question (plug gap)
Old Jan 26, 2006 | 05:23 PM
angrystick87's Avatar
angrystick87
Default newbie question (plug gap)
the backgound-I have a punched out 302 to a 306 with stock but ported heads and a gt-40 valve train
The question- what should I gap my plugs, and are there any suggested replacement plugs that anyone can suggest
thanks
Old Jan 27, 2006 | 02:08 AM
87GTHO's Avatar
87GTHO
Default RE: newbie question (plug gap)
Generally speaking you want to use cooler plugs for a higher performance engine. There named cold plugs becausethey have shorter insulatornoses, to expel heat.
It should be in the .45 inch range on a normally aspirated engine and around .29-.35 inch on cars running forced induction. its a good idea to coat the threads with an anti seize compound befor installation.
Old Jan 27, 2006 | 03:27 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: 87GTHO
Also use Dilectric grease on the plug boots. Makes it easier to remove them when you change the plugs.
Old Jan 29, 2006 | 03:33 PM
angrystick87
Thanks for the advice. Its been about 32,000 miles on these same plugs and wires, its time.
Old Jan 29, 2006 | 03:49 PM
87GTHO's Avatar
87GTHO
No problem , Im in the same boat as you are, i just got some new msd wires, a new cap and rotor and blaster coil.
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
cbird1177711
Sep 2, 2015 04:12 PM
