Newb has Welding Q
Old Jan 27, 2006 | 02:14 PM
CRIMPS66's Avatar
CRIMPS66
Default Newb has Welding Q
I am starting to repair some rust holes in my 66 Coupe. I was going to cut out the rust and weld new sheet metal in. I take it most people, when welding on the body, use a wire feeder welder instead of a stick welder. This way you have less mess and cleaner welds. I need to buy a welder on the cheap side. Also, what gauge is the sheet metal on the older stangs? This should be pretty easy to find, right?
Z
Old Jan 27, 2006 | 08:29 PM
Tim37's Avatar
Tim37
Default RE: Newb has Welding Q
ok first off yes you need a mig welder preferably a gas shielded welder. they arn't cheap.
i think its about 16 or 18 gauge on the body.
there is some tricks to welding on the body that you need to lear befor jumping right in if you just do a continous weld it will warp the panel and cause you to have to use a ton of bondo to cover it all and make it look right. thr trick is to get the metal in to place and then tack it in then go around and make quarter inch tacks about half an inch apart all the way around let cool and repeat untill it is fully welded then you have to grind your weld down.
Old Jan 27, 2006 | 09:38 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Pretty close Tim, but you want to spread the welds out even more, start at one side and then move to the other and so on. Also there are some heat gels that you can put on the panel. Honestly dude, this is not the type of work for a newb welder to try, there is a lot that can go wrong and it will be very very costly to fix if you warp the panels.
Old Jan 28, 2006 | 02:16 AM
nelson95's Avatar
nelson95
i also agree with these guys this is somthing that you should have exp in do it on a budddys car first and to use stick it is not prefered but i have a friend that did it once looked like swiss cheese until he got the hang of i lets just say a magnet would nots stick any where
Old Jan 28, 2006 | 02:21 PM
CRIMPS66's Avatar
CRIMPS66
Thanks for the info. I have done some welding in the past, just not on a body of a car. Since I am in no hurry to get her on the road and I want to learn, I think I will go ahead and try it. If I do a crap job I will just start over.
But very good info.
Z
Old Jan 28, 2006 | 03:36 PM
posnick's Avatar
posnick
the metal on the car is 22 gauge. if your worried about warping the panel just tack it all the way around instaed of running a continuos bead. i just did my 1/4 panel and it turned out fine. all you need is a 110 mig welder for this. your average $500 welder is good.
Old Jan 28, 2006 | 09:26 PM
CRIMPS66's Avatar
CRIMPS66
Thats good info. This sheet metal isn't too hard to find, probably from any steel supply company, right?
Old Jan 29, 2006 | 12:35 AM
posnick's Avatar
posnick
any steel supply will do. around here the local hardware store has it too
Old Jan 31, 2006 | 12:18 AM
JD1969's Avatar
JD1969
ORIGINAL: CRIMPS66
Why don't you just buy pre-formed replacement panels? And tack welding is not only a good idea it's the right way to do it, a bead WILL warp the panel very badly. FWIW I am a welder by trade.
Old Jan 31, 2006 | 12:15 PM
roadrunner's Avatar
roadrunner
dont do it, I tried to weld a quarter on my old can am warped the panel and it cost alot to get fixed. Just have some one weld it up and finish it yourself. Would save you alot of headache
cyclop5
Oct 3, 2015 09:21 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 17, 2015 07:57 PM
cardsrus1
19
Sep 15, 2015 08:37 AM
MusBBad95
Aug 17, 2015 09:39 PM
