shock/strut/caster camber plate ?????
Old Jan 28, 2006 | 12:51 AM
1BIGMOFO's Avatar
1BIGMOFO
Default shock/strut/caster camber plate ?????
I purchesed a set of KYB AGX 8 position gas shocks and a set of caster camber plates from upr products. anyone have any install tips.. i am pretty handy but I have never done shocks and struts before. I also have rear upper and lower control arms, will they be easiest to install together! thanks!!! Bob
Old Jan 28, 2006 | 01:20 PM
Tim37's Avatar
Tim37
Default RE: shock/strut/caster camber plate ?????
struts are not bad to install just make sure you don't let the spring jump out at you. i used to like to do them on the ground and keep a jack under the a-frame.
on the upper and lowers its easier to do them in the air. take the shocks loose then pop the springs out you don't need to compress them. then its just a matter of swapping every thing out make sure you keep the rear supported so you don't damage the break lines.
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
