What motor oil?
Old Jan 30, 2004 | 09:41 AM
shacar87's Avatar
shacar87
Default What motor oil?
I agree, Synthetics all the way.
Think about the fact that when you break in a brand new motor, you are NOT supposed to use Synth. oil because it doesn't actually allow the internal parts to wear or break-in properly...it's too slippery! Only after about the recommended first 1500 to 2000 miles, should you start using Synth. oil. If you're skeptical, ask around at your local machine shops, and even call Summit or Jegs Tech line.
I also know of some local drag racers that have switched to Synth. Tranny fluid, and upon doing so, the tranny temp. would run up to 20 degrees cooler (less friction) with NO other changes! If that doesn't prove it to ya than i guess nothing will! Just do some research on it, and see for yourself.
Old Jan 30, 2004 | 03:39 PM
kylx's Avatar
kylx
Vavoline 20 50 racing formula
Old Jan 30, 2004 | 04:03 PM
vfast's Avatar
vfast
I ♥ Acer
dan..could you please be a lil more indepth about it*L*
I like amsoil and redline...of coarse a good filter is just as key...
Old Jan 30, 2004 | 05:58 PM
mkspeed26's Avatar
mkspeed26
</P>
fram all the way for the filter <IMG src=smileys/smiley2.gif border="0"></P>
i like mobil 1 and valvoline, and synthetic</P>
Old Jan 30, 2004 | 06:56 PM
JHonor's Avatar
JHonor
Definitely synthetic. I run Amsoil synthetic and it stays pretty clean even when it has been in the 4000+ miles. Keeps my mileage nice and high too, and car never sounds like it's struggling to crank up in the winter.
Old Jan 30, 2004 | 07:14 PM
Dan04COBRA's Avatar
Dan04COBRA
</P>
You summed it up pretty good!!</P>
Old Jan 30, 2004 | 07:21 PM
hotrodman's Avatar
hotrodman
I ♥ Acer
REG. 5/30 WT. CHANGE OIL EVERY 1000 MILES...
Old Jan 30, 2004 | 11:50 PM
vfast's Avatar
vfast
I ♥ Acer
mk..I was a fram user for years until I went to a filter test and fram was near the bottom
top one were
hasting
mobil 1...I was surpised
amsoil filters are made by hastings
Old Jan 31, 2004 | 04:43 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
I run 20/50 just for added protection in the summer months only.I dont drive it in winter so i could care less about it starting in the winter.
Old Jan 31, 2004 | 05:18 AM
tyybo's Avatar
tyybo
I use durablend oil by valvoline, in northdakota you cant get along with conventional oil, most of my other family members use Ams.
