What motor oil?
Old Jan 31, 2004 | 11:09 AM
  #21
vfast's Avatar
vfast
I ♥ Acer
Default What motor oil?
tyypo..you need full syth. oil in that cold as climate..
I put a oil primper unit on my 67 car will not fire til I have atleast 15 psi of oil pressure...coarse it has a $20k in it..
Old Jan 31, 2004 | 02:11 PM
  #22
shacar87's Avatar
shacar87
Originally Posted by vfast
mk..I was a fram user for years until I went to a filter test and fram was near the bottom
top one were
hasting
mobil 1...I was surpised
amsoil filters are made by hastings
I agree, i'm pretty good friends with a local performance shop owner. He builds and races just about anything on 4 wheels (although i have to add, all of his personal vehicles are FORD), and i've asked him about this issue and he has done tests on his personal cars that have high HP numbers, and after cutting open the filter after the test runs, he found that the Frams have blown apart inside...a few different times! He told me not to buy the regular Fram filters, that if i don't want to spend the money on a good, expensive brand like above, and have to use Fram, only use the Fram Tough Guard, he said it's better quality and it's the only Fram he tested that didn't blow apart inside. Hope this helps you guys out!
Old Jan 31, 2004 | 05:54 PM
  #23
jeep45238's Avatar
jeep45238
I ♥ Acer
I hate Fram's valve design, plastic and rarely forms a good seal, letting the oil drain back instead of stay put for the next start up. I personally use Purolator 1 filters, freakin awsome. I figure that $6 for a filter and $15 for a jug of Mobil 1 is worth having a motor that works, but maybe that's just me.
Old Jan 31, 2004 | 10:44 PM
  #24
Ormist's Avatar
Ormist
Is it true that if you use synthetic oil it is realy bad for your engin to go to non-synthetic? <edited><editID>Ormist</editID><editDate>38017.8649768519</editDate></edited>
Old Jan 31, 2004 | 11:24 PM
  #25
vfast's Avatar
vfast
I ♥ Acer
you can change anytime you want there will be no problem...shoot that make the syth. blend thats the 2 mixed..well sorta..
Old Feb 1, 2004 | 06:42 AM
  #26
MelloYello's Avatar
MelloYello
<FONT color=black size=3>Royal Purple user here....</FONT></P>
<FONT size=3>MEL</FONT></P>
jc409
Convertible Tech
Sep 24, 2015 03:38 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
rksnow1
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
jaiidutch
Sep 14, 2015 10:29 AM
