Dyno Graph - Looks Weird
Old Feb 3, 2006 | 01:02 AM
TBird232ci's Avatar
TBird232ci
Default RE: Dyno Graph - Looks Weird
ORIGINAL: namezod
redline 4750rpm, speed limiter hit at 112 miles per hour so we could not pull to redline. i didn't want a tune or remove speed limiter yet.
The loop is you hitting your limiter, the RPMs go down, there for dropping the graph backwards, making your loop.
Old Feb 3, 2006 | 01:25 AM
HaV's Avatar
HaV
ORIGINAL: TBird232ci
ORIGINAL: namezod
[sm=youreright.gif]
Yep. Makes sense to me.
Old Feb 3, 2006 | 10:36 AM
namezod's Avatar
namezod
if it was my limiter wouldn't there be more loops?
I mean, there is one loop at mid-rpm, and then we continue to pull past the loop for a bit. If it was a rev-limiter the dyno graph wouldn't read past the rpm limit, right?
Old Feb 3, 2006 | 11:54 AM
gt96stang's Avatar
gt96stang
ORIGINAL: namezod
He never hit at redline.
But why is your redline so low, I didn't think that the v6's revved that low.
Also, what gear was this done in?
Old Feb 3, 2006 | 12:46 PM
Tim37's Avatar
Tim37
its the awsome power of the stock sixer it has so much power that it made the dyno flip.
Old Feb 3, 2006 | 04:19 PM
namezod's Avatar
namezod
ORIGINAL: Tim37
that is EXACTLY what i was thinking!
Old Feb 3, 2006 | 04:39 PM
Tim37's Avatar
Tim37
http://i27.photobucket.com/albums/c1.../hotwheels.jpg
lol its a hotwheels track.
Old Feb 6, 2006 | 11:02 AM
angcobra's Avatar
angcobra
I think it is an issue with the dyno, if you notice it shows up on the HP and the TQ at the exact same time on each run. Where it shows up on each run is not related to a RPM, HP, or TQ number, it is related to the time after the start of run. Look where the curve actually starts and measure across, for both runs the time is identical from the start. I would say it has something to do with some timing event triggered by the start of the dyno run.
Old Feb 6, 2006 | 11:42 AM
steve_mustang89's Avatar
steve_mustang89
ORIGINAL: Tim37
haha nice! and ya could also be something with the transmission slipping or something if its an auto something could be worn out or if its manual maybe just the way you shift? other than that no idea
Old Feb 6, 2006 | 11:44 AM
angcobra's Avatar
angcobra
It is the dyno, nothing about the car can make time run backwards. The graph is per unit time, to loop when mean time went backwards.
