Help me please!
Old Feb 1, 2004 | 08:02 PM
Ormist's Avatar
Ormist
Default Help me please!
I installed a new thermostat and when I started my car it started to leak coolant, this happened to me before but after like 10 minutes when the gaskent binds itself to the metal it stops, is this normal????
Old Feb 1, 2004 | 09:28 PM
mcgyver8062's Avatar
mcgyver8062
No, it shoudn't leak at all, tell me you didn't put a cheap piece of chrome thermostat housing on it, they are terrible to keep from leaking. If you just replaced the stock one did you make sure you put the gasket under it, or I have seen a rubber o-ring seal. But if you do it correctly, tightening them evenly it should not leak!
Old Feb 1, 2004 | 09:51 PM
FastFoedBoy's Avatar
FastFoedBoy
If it is chrome. Wouldn't a slight bead of sealer cure that?</P>
Old Feb 1, 2004 | 10:16 PM
Ormist's Avatar
Ormist
Nah theres no chrome, and if I read correctly the gasket is on the elbow side right? If thats right anyone have any idea why its leaking, Imean it leaks very bad.. and I should of said for more like 20 minutes...
Old Feb 2, 2004 | 04:39 AM
johnc's Avatar
johnc
</P>
Did you use different bolts? One may have too long a shank and the thread bottoms out on it so it feels tight, but has a small gap?</P>
Old Feb 2, 2004 | 10:38 AM
vfast's Avatar
vfast
I ♥ Acer
I bet when installed the stat it slipped down and is out of the groove and has put a crack in the stat housing...hope not..but check it..
Old Feb 2, 2004 | 11:21 AM
hotrodman's Avatar
hotrodman
I ♥ Acer
dont get a cheap gasket....
Old Feb 2, 2004 | 03:02 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Vfast hit it on the head.Thats what happened i did it myself last summer and was pissed.</P>
Since you have to do it again go ahead and get a tube of RTV silicone and go around the housing and then apply your thermostat and then the gasket and allow this 10-15 minutes to set up.This will ensure you that your gasket and thermostat stay in place.And whatever you do do not over tighten those bolts especially on an aluminum intake.</P>
