make tires sticky
Old Feb 6, 2006 | 01:36 AM
01musgt's Avatar
01musgt
Default make tires sticky
is there a cheap way to make your tires sticky when racing at the tracks
what can you use(for street performance tires)
Old Feb 6, 2006 | 03:12 AM
StanginZach's Avatar
StanginZach
Default RE: make tires sticky
Heat them up a little bit. I was told by a couple people here on the forums that it wouldn't help for just street tires... but everyone at the track said to try it, and my times were horrible anyway. After starting to do a short burnout before launching, my times did get a LITTLE better.
I ended up with a 14.205 @ 97.61 with no changes to my stang except a flowmaster cat-back, and a BBK aluminium CAI (useless). So I was essentially stock, factory tires too.
There's not much else you can do to make a set of tires stickier... the best you can do is just get some different tires.
Old Feb 6, 2006 | 03:13 AM
ShadowDrake's Avatar
ShadowDrake
Looks like my friend just got a free post [:@] Seems he forgot to log out from my PC after leaving here. The above post was by me.
Oops.
Old Feb 6, 2006 | 01:14 PM
Tim37's Avatar
Tim37
for the most part street radials dont' do good when heated it will pull the oils out of the tires making the slicker. just turn them over a couple of times to clean them off drop the air preasure down to about 28 psi and maybe use some track bite.
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
