Retrofit hydrolic roller lifters
Old Feb 12, 2006 | 02:52 AM
Quackus's Avatar
Quackus
Default Retrofit hydrolic roller lifters
I started to rebuild my 1969 351w I have a mild hydrolic flat tappit cam. My budget has increased and I can now reasonably afford the retrofit roller lifters that ford and other various companys produce. My question is can I use the same flat tappet cam or would I need to change to a roller cam if I wanted the roller lifters?
Thanks!
Old Feb 12, 2006 | 11:29 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Retrofit hydrolic roller lifters
Roller lifters need a roller cam. I suppose you could use a flat tappet cam but defeats the whole purpose of rollers. Rollers allow for a more aggressive ramp on the cam lobe (faster opening and closing). Why you just use a roller lifter on a non-roller cam is beyond me, there would be absolutly no benifit at all, just a waist of money. You also will need to modify the block to run the roller lifter in a non-roller block.
Old Feb 14, 2006 | 12:40 PM
Tim37's Avatar
Tim37
wouldn't using a flat tappet cam with roller lifters cause strange lifter wear?
uedlose
Sep 30, 2015 08:01 AM
Tyoung68
Aug 25, 2015 04:31 AM
WDScott
Aug 17, 2015 06:38 AM
ding56
Aug 14, 2015 02:40 AM
69fastback302
Nov 12, 2003 06:53 PM
