First Time Doing Body Work....
Old Feb 17, 2006 | 02:08 PM
88BlueGT's Avatar
88BlueGT
Default First Time Doing Body Work....
Yes, its my FIRST time doing body work and I dont have a clue what I' am doing I'm in the process of sanding down my doors and doing some bondo work. I know that there are a lot of little tips and tricks. Anyone willing to share Also, its not a throw together project so I need all the info I can take in. Also, whats the best body filler to use? Is there a difference? I will basically spend any amount of $ to get the best. Thanks alot guys!
Dan
Old Feb 17, 2006 | 02:55 PM
Tim37's Avatar
Tim37
Default RE: First Time Doing Body Work....
i think jd1969 will be able to help you alot but one thing you need ot do if you want the best possible resluts is to finde somthing to practice on. once you get the hang of it then go to work on your car. labor is much more important in body work than matirials. it takes a lot of practic to get the hang of it.
Old Feb 17, 2006 | 03:52 PM
ben5.0's Avatar
ben5.0
Use bondo. If you mess up, just sand it down and start over.Body work is kind of hard to tell someone how to do. So its like you make some good progress, and then other times you mess up. Post some pictures of the dents and stuff you are going to use body filler on. Also one tip that i have, is to put sum bondo on, sand it down, then run it from a different direction. this makes it stronger. I just finished some major bondo and sanding work on my gt. if you have specific questions, feel free to ask.
Do you plan on painting the car urself?
Old Feb 17, 2006 | 09:52 PM
88BlueGT's Avatar
88BlueGT
I will not be painting the car myself. The thing is, the body needs to be "show quality" but I really want the experience and Im already spending a couple G's on just having the car painted and buying paint ("Olive Green" from the 2006 Porsche Carerra S) so it needs to be GOOD.
88BlueGT's Avatar
88BlueGT
Any suggestion on materials?
Old Feb 18, 2006 | 12:28 AM
ben5.0's Avatar
ben5.0
i would just go to a body shop, and ask questions man.. ask the professionals, see what their using, if you want it show quality.
Old Feb 18, 2006 | 12:37 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Please only make one post with same question.
djbigskrilla
Sep 20, 2022 01:04 AM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
