Front end shaking
Old Feb 22, 2006 | 11:06 PM
Smooth_J's Avatar
Smooth_J
Default RE: Front end shaking
ORIGINAL: MikeHawke
check the rotors?
Breaks were just redone ~3 months ago.
Thanks everyone for the advice so far!
Old Feb 23, 2006 | 01:56 PM
Tim37's Avatar
Tim37
ORIGINAL: MikeHawke
check the rotors?
that would only cause problems when he aplied the breaks.
Old Feb 24, 2006 | 03:07 PM
Deannostang's Avatar
Deannostang
High-speed shaking is due to improper front end alignment and/or tire balance. Tire pressure can also sometimes play into the factor as well. If you do nothing but have your tires rebalanced and rotated, there is a very good chance all your vibration will disappear. If not, check into your alignment but be sure to tell the shop you have high-speed shaking. I kind of shake a little myself at around 150. Sometimes it is a matter of one bad tire that is out of round and you can do nothing about it unless you isolate that tire and replace it. Good luck!
Old Feb 25, 2006 | 12:06 AM
Smooth_J's Avatar
Smooth_J
ORIGINAL: Deannostang
I went to another shop today and they re-did the rotation, balancing, and alignment. I drove my car on the highway and noticed it was ALOT better. Thank you everyone for all your help
Old Feb 25, 2006 | 01:20 AM
StreetRod Steve's Avatar
StreetRod Steve
Cupped tires - that's my bet.
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
