chip for 2.3L
Old Feb 22, 2006 | 11:11 AM
89ITBstang's Avatar
89ITBstang
Default chip for 2.3L
Hey friends,
I need more power, any body know where I can get a chip for a 2.3L. non-turbo.
run in scca so i am limited as to what I can "legally" do to the motor.
thanks
Old Feb 22, 2006 | 12:18 PM
Tim37's Avatar
Tim37
Default RE: chip for 2.3L
it will probably have to be done on a tuner. you can put a ranger cam in it that will give it a little more pep.
Old Feb 22, 2006 | 06:07 PM
TBird232ci's Avatar
TBird232ci
Diablo Sport is the only company i can remember making chips for the N/A 2.3L.
What are your limitations? The best things you can do for power, aside from porting and a cam is a header, 2.25" exhaust, gears (depending on whats stock in your car), and all the *little* mods. Other than that, everything else is pretty much useless.
Old Feb 27, 2006 | 06:24 PM
89ITBstang's Avatar
89ITBstang
Thanks for the info.
I already have a header. Have port matched the intake and exhaust. can not ( legally ) replacethe cam unless it is (stock), but that thought has crossed my mind. would need to reprogram to take full advantage of the new grind?
that is a sweet bird
Old Feb 27, 2006 | 06:34 PM
89ITBstang's Avatar
89ITBstang
thanks, i understand there was a twin plug head used on the ranger. do you know anything about this? will it bolt right up?
Diode Dynamics
28
May 26, 2022 12:02 PM
jlopret
2.3L Eco-Boost Tech
Nov 19, 2015 10:32 AM
1TUFF302
Nov 5, 2015 04:02 PM
ShaneB26154
Aug 28, 2015 04:47 PM
