Basic Tuning for "Dummies"?
Old Feb 23, 2006 | 12:05 PM
jjfrehe's Avatar
jjfrehe
Default Basic Tuning for "Dummies"?
Hey there - I just bought a 2003 GT convertible, and am having a great time with it. We already installed a Magnaflow catback and bought a Diablo Tuner. This weekend, Im installing a 85mm MAF and an Accufab TB/Plenum.
The primary issue Im concerned with is running too lean with these mods. Has anyone ever seen a basic "tutorial" regarding performiung basic tuning adjustments with a Diablo or SCT for that matter? Right now I simply have the "Diablo Tune" loaded up but would like to tweak it a bit this weekend.
Thanks for the help.
Old Feb 23, 2006 | 04:14 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: Basic Tuning for "Dummies"?
the predator is pretty safe. It won't let you do enough to REALLY hurt your engine.
That being said, you should ALWAYS exercise caution and make adjustments in small increments.
Play with it and have fun.....remember that most of the setting only take effect at WOT.
Old Feb 23, 2006 | 07:41 PM
sandcracker21's Avatar
sandcracker21
i wouldnt be concerned too much with running lean
but if you want to be safe, then the pred. can be used to force the engine to run a little more rich
its a great tool, you can tweekvirtually anything
Old Feb 23, 2006 | 07:50 PM
jjfrehe's Avatar
jjfrehe
ORIGINAL: sandcracker21
What parameters would you adjust to "add fuel"?
Old Feb 23, 2006 | 10:17 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: jjfrehe
I HIGHLY recommend you DO NOT adjust the air/fuel mix unless you have A:the experience, and B: the proper meters. It's real easy to mess it up.
Old Feb 24, 2006 | 01:59 AM
xxkazp3rxx's Avatar
xxkazp3rxx
+1 - If you're worried about it being to lean - take it to someone that can dyno tune your car, which means basically they run a dyno and based on the dyno information they develop you a new tune for your car. That's goin to be the best bet for you really, especially if you're worried about running to lean... After I tuned my car for my FIPK K&N kit, I was told by SCT that it wasn't necessary to retune it for a TB/Plenum combo that i should be running a good mixture, as far as the MAF, I have no idea if it even needs to be retuned, but that Dyno tune will be able to tell you everything you need to know.
Old Feb 24, 2006 | 02:58 PM
Deannostang's Avatar
Deannostang
The new SCT X-Calibrator V2 is supposed to be one of the best on the market and absolutely gives you the most overall adjustments of any calibrator on the market. If you are a really concerned, modified Mustang GT/Cobra owner, give yourself a treat and get a dyno tune. Still no substitute for using such hi-buck equipment to dial your Mustang into its total maximum potential. Not all areas have a dyno near by but it is worth the trip if you ever get the chance.
Old Dec 11, 2008 | 10:20 AM
Trakpak's Avatar
Trakpak
Is there anyone in this forum that isn't an expert? Answer the mans question. If he wanted all that added opinion he would have asked for it.
Old Dec 13, 2008 | 11:29 PM
FoxGT's Avatar
FoxGT
If you're trying to tune it well yourself I would suggest buying a cheap wideband o2 controller. Summit sells a kit that uses the lc1 controller with a summit digital gauge which can datalog if a computer is connected (will not log without it). You can also find an aem 6in1 on ebay fairly cheap. Both are going to run you about $250 shipped & I've had no problem with either. It won't be able to give you a dyno #, but it can help you get your fuel curve down.
Toying around with lean condition at low or moderate load is ok (like cruising & light acceleration) How much you lean it out should depend on whether you care about emissions or fuel economy, you can't have both. For max fuel economy you want to run as lean as possible, when the car starts surging from being too lean back off a couple points. (most cars will start surging in the 16's:1) For emissions staying around 14.7 is best in most cases.
As for heavy load & wot. You don't want to play around with running lean there, while it's ok to do it at low load at wot or heavy load there is enough air/fuel to generate alot more heat which can ramp up temperatures very high causing parts to melt (literally). So until you get a wideband controller for your car or a dyno I would recommend not playing with it in high load. An egt gauge will work but they're not as responsive & you'll want to have a baseline to go off of.
mapitts
May 15, 2016 02:57 AM
Oct 7, 2015 07:02 PM
firecoyote
Sep 27, 2015 02:37 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Emblazoned
Sep 3, 2015 10:45 PM
