redline
Old Feb 24, 2006 | 03:59 PM
namezod's Avatar
namezod
Default redline
how far do you guys take your rpms up? my auto is shifting at 4900rpm while my tach goes up to 7000. where do you guys shift at for max acceleration?
Old Feb 24, 2006 | 04:02 PM
Tim37's Avatar
Tim37
Default RE: redline
about 6k
Old Feb 24, 2006 | 04:20 PM
Chopper's Avatar
Chopper
Default RE: redline
That depends on your mods.Without a dyno graph to actually see where your power starts to fall off it's impossible to give an answer.If you want to get some idea of where to set your shift points,leave the tranny in first gear and floor the gas.When acceleration starts to fall off,remember the tach reading.Do this a couple of times to be sure and have the tranny set to shift at that tach reading at WOT.
Old Feb 24, 2006 | 11:58 PM
Smooth_J's Avatar
Smooth_J
Default RE: redline
Speaking about readline, if I floor my mustang (I have a auto) it shifts right before redline (at 5800 rpm). Is that normal?
Old Feb 25, 2006 | 12:21 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: redline
i shift at about 5800. I'd think it would be normal for the auto to shift at least closer to redline than 4900. Anyone else have an auto?
Old Feb 25, 2006 | 02:08 AM
XxphantomsnypzxX's Avatar
XxphantomsnypzxX
Default RE: redline
my auto shifts at like 5500ish,
Old Feb 25, 2006 | 04:18 PM
85pro50mustang's Avatar
85pro50mustang
Default RE: redline
eeeech
AOD...=( that stinks..lol just kiddin
LUKE
i shift at 6800 but thats cause its not stock
Old Feb 26, 2006 | 09:57 AM
uedlose's Avatar
uedlose
Default RE: redline
most stock 5.0 motor start to fall off around 5200.on the factory tach. we shift the wife's car at 6700 we where shifting at 7200 but found that we where over spinning the super charger with the new small pulley so we backed up the shift point
Old Feb 26, 2006 | 11:15 AM
alexr's Avatar
alexr
Default RE: redline
my auto shifts at 4500 but then again, my tach only goes to 5.5 or 6k
Old Feb 26, 2006 | 11:34 AM
1BAD3V's Avatar
1BAD3V
Default RE: redline
An auto should be shifting right before redline and a manual you should shift barely into redline.
