Gas in Oil
Old Feb 12, 2004 | 09:03 PM
Cdprowl's Avatar
Cdprowl
Default Gas in Oil
Yeah, I have gas in my oil and it smells, there are many solutions we can think of cracked gasket, cracked cylyinder, not enough spark on ignition. Anyone have any clues why? I am losing horse power and my torque is shot.</P>
Also when I first start my car it shakes rattles and rolls think it could be a fuel filter that just needs to be replaced or need higher pounds per hour fuel injectors?</P>
Old Feb 12, 2004 | 10:47 PM
vfast's Avatar
vfast
I ♥ Acer
Default Gas in Oil
I'd say your running rich as hell...any codes?..if you have alot of gas in the oil as you always will have a lil change the oil before you wash the walls down
Old Feb 13, 2004 | 10:44 PM
mkspeed26's Avatar
mkspeed26
Default Gas in Oil
if there is gas in the crankcase your rings could be goin bad. try this-do aleakdown test (there should be no more than 20% leakage).if it is more than that, open up the crankcase oil fill cap and listen inside the crankcase for a hissing. if you hear a hissing, your rings are probably going bad. </P>
Old Feb 13, 2004 | 10:48 PM
Cdprowl's Avatar
Cdprowl
Default Gas in Oil
Yeah I am thinking the piston rings or a cracked head.....Oh god I don't want to spend any more money. Because it was a point to where the oil was runny like water. That thin.
Old Feb 14, 2004 | 02:08 AM
vfast's Avatar
vfast
I ♥ Acer
Default Gas in Oil
you have washed the walls down..not a good thing..I'm sure your 02 sensors are gone<img border="0" src=smileys/smiley16.gif border="0">
Old Feb 14, 2004 | 04:48 AM
NeoTokyo's Avatar
NeoTokyo
Default Gas in Oil
What year mustang and what size engine do you have? Perhaps you would be better off buying a whole new engine and using your old as something to build up and tinker around with.... In most cases buying a whole new engine and putting it in is cheaper then replacing bottom end components.</P>
Plus if it were me i WOULD buy a new/rebuilt engine for it and build up the old and swap them when your ready<IMG src=smileys/smiley16.gif border="0"> </P>
Old Feb 14, 2004 | 08:31 PM
mkspeed26's Avatar
mkspeed26
Default Gas in Oil
its a good excuse to mod it!
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
wraith777
Sep 28, 2015 10:49 AM
