2000 gt won't start
Old Feb 25, 2006 | 11:20 PM
2000gtfun's Avatar
2000gtfun
Default 2000 gt won't start
I have a 2000 gt that will rev when starting but won't catch. The GT will do this for about 15 minutes and then eventually catch and start. The problem comes and goes. It will work fine for 2 or 3 weeks then start acting up. I live in Orlando and it seems to only do it when it is humid or damp out. Any help would be greatly appreciated as no mechanic I've gone to so far has an answer. Thanks!
Old Feb 27, 2006 | 12:34 PM
Tim37's Avatar
Tim37
Default RE: 2000 gt won't start
tps maybe?
Old Feb 27, 2006 | 02:36 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
my educated guess:
Idle Air Controller.
it controlls well,, the air when idleing
there is a small spring that handles this, and its VERY VERY VERY common on many 4.6's (not just Mustangs) to stick, thus causing your problem
let me guess, if you continue giving it gas, you can keep it running, but the rpms just DIVE the moment you get off the throttle..
there is a 4.6 thread about it in the sticky section, check there, then try some of their suggestions
ive got a picture showing you (sort of) where it is, its held on by i believe two small screws, and the fix can be pretty simple
for starters, next time it acts up, just tap on it with a screwdriver or something else solid
(seems silly, but it is a very temporary fix to get you to where you are going)
then, take it apart, and clean it with carberator cleaner, this fixes the problem in most cases
however, if you still experiance the problem, its no more thnan 70$ at a normal auto parts store
[IMG]local://upfiles/11183/94F11B570C164F24B57B42C23212D8FD.jpg[/IMG]
Old Feb 27, 2006 | 11:49 PM
2000gtfun's Avatar
2000gtfun
Thanks for that. Found that sticky after I posted this and I cleaned the IAC and so far so good. Thanks for the help!
Old Feb 28, 2006 | 12:32 AM
StickShifty's Avatar
StickShifty
ORIGINAL: 72MachOne99GT
my educated guess:
let me get out my magnafying glass for that pic.
just kidding mach
Granatelli Sales
Jan 20, 2020 12:34 AM
2007StangV6
Jan 28, 2016 06:09 PM
StalkerGT
Sep 25, 2015 02:41 PM
5.0 kevo
Sep 3, 2015 06:24 PM
