Oil Change
Old Mar 1, 2006 | 01:07 AM
Claytone's Avatar
Claytone
Default Oil Change
Anyone done it? How difficult is it compared to other cars?
Old Mar 1, 2006 | 02:35 AM
karazuba's Avatar
karazuba
Default RE: Oil Change
i am sure a lot of us have done it.
just as easy as any other car. good access to filter, drain plug.
Old Mar 1, 2006 | 10:05 AM
ren274u's Avatar
ren274u
easiest car i have changed the oil on.
Old Mar 1, 2006 | 11:39 AM
Pennstate57's Avatar
Pennstate57
Does anyone know the recomended mileage to get ur first oil change?
Old Mar 1, 2006 | 03:57 PM
Stoenr's Avatar
Stoenr
ORIGINAL: Pennstate57
Try the searcdh function, this has been talked about alot.
Everyones reply will be different
I did mine at 500, then 3000, 6000, 9000 etc.
It is a very easy oil change, just watch the oil filter drainage and where it goes.
This was on my 1st oil change
Old Mar 1, 2006 | 09:44 PM
masterchiefbt's Avatar
masterchiefbt
I agree....the easiest car I have done yet![sm=signs003.gif]
Old Mar 2, 2006 | 01:27 AM
pastor_ice43's Avatar
pastor_ice43
it gives you a schedual on when to get all your regular stuff done....oil changes, tire rotations, tranny service, ect. I believe the oil changes are every 5000 miles.
Old Mar 2, 2006 | 01:31 AM
gkosin's Avatar
gkosin
Default Oil on the hose below the filter
I had the same issue. Can't these engineers figure out a way to keep directly below the filter clear. I just put a rag over that line but I'm sure someone on these forums has come up with a clever idea to solve this.
Greg
Old Mar 2, 2006 | 09:26 AM
B767capt's Avatar
B767capt
Default RE: Oil on the hose below the filter
With a nail, I punch a hole in the lower end of the filter and let it drain. After loosening the filter with the filter wrench, I then slide a Wal-Mart bag over the whole filter and spin it off. I don't spill a drop.
Old Mar 2, 2006 | 09:49 AM
MikeVistaBlue06's Avatar
MikeVistaBlue06
I ♥ Acer
I have to jack mine up to get to the oil plug. I'm too thick through the middle to crawl under it!
Other than that, it is pretty straight forward. The oil filter is easy to remove and replace.
Thx,
Mike
