I just do not get it...
Men.. I just do not get it... I have being reading your times for 1/4 m and I do not know what I am doing wrong...
I had my first chance on the drags with my stock 2006 GT but my best time in 8 passes was 15.42 [:@][:@][:@]
The car is 100% stock, it had 650 miles on, new oil, track conditions was not good but the time !@#$%^&*().... the track was at 2600 mts (8500 ft) and weather was dry but cold, 8 deg C (46 deg F).
I tryied with TC on and off and almost the same result, tire pressure was 25 - 30 psi for back set and 35 for front set... any idea... besides a not very good driver???
Thanks.
Thanks.
RE: I just do not get it...
The engine may not be completely broken in either with only 650 miles on it. I would really wait until you broke 1k before you really start pushing you car hard. Give your engine time to "glue" together so to speak.
what were ur 60' times? the biggest killer is too much spin off the line. Hell, I would rather lose a second starting real slow than lose two by spinning through two gears (which ive done [:'(])
ORIGINAL: Pipe_Rueda
Thanks.
Thanks.
me at 100' above sea level=first and most of second gear get no traction and when they do i get thrown back
me at 6500' near lake tahoe=wtf this thing feels slower than my mom's saturn
conclusion=high altitude means lower air density which results in less air mass into the engine in a given volume and thus, less fuel burnt...all ending up with you getting less power.
try it again at sea level, i think you might be surprised
ORIGINAL: JML
Our cars at this altitude are slow. any N/A car here looses around 30% of the power, so if we dyno´ed our cars at the wheels without compensating the altitude, I guess we´ll be hitting around 220-230 whp...
+1, HP decreases with altitude at approxiamately 3% for every 1000 feet above sea level. which mean at 8500', you have 25.5% less hp then a guy on the coast. For an example, a stock 05 GT Manual, has about 265 RWHP at sea level on a standard day.
My OWN car, (mustang dyno'd) at my Level of 3500', was 239.5 hp...
265 - 10.5% = 239.82 RWHP
YOUR car, because it's so high up
265 - 25.5% = 211 RWHP...
Conclusion: Drive to a sea level track, you'll get your 13's.
