HELP failed emissions Saleen Supercharged
RE: HELP failed emissions Saleen Supercharged
Sure, depending on what type of test they do. If it is a sniff, as long as it is clean enough it's fine. If it is an OBDII scan, what you need is an O2 simulator. I'm by no means encouraging or recommending people remove their cats (my disclaimer ) but the O2 simulator will take the signal from the downstream sensor and feed it back to the PCM as a good signal (within propper range). I did this on my previous car and it passed the sniff test. When they changed to OBDII scan, I had to put in the O2 simulator. If they do a visual, you'll need someone to make you bolt-in cats. It's actually easier to start with an x-pipe with cats, have them cut them out and weld a flange on the other side so it can be bolted back in. Then at the track only use a test pipe. -Joe
Well with the O/R H-pipe and SLP Loudmouths, they'll probably want to do a visual check if everything comes up clean and clear on their systems... lol. I'm most likely just going to slip on my stock H pipe real quick anyway. I don't think I need to get inspected for like 4 years anyway... who knows if I'll even be living in NJ by then.
Wow 4 years, that's great! In Maryland we get tested every 2 years. I wish I was in a state that didn't even have emsissions testing. I'm very glad I'm not in CA, I've heard some real horror stories about the crap they put those guys through. -Joe
ORIGINAL: satinsilvergt
They don’t give you an inspection sticker. So I have 30 days to fix it or I won't be able to legally drive it.
In addition to my GT, I also have a gas miser Honda HX for daily driving and beating around. There is absolutely NO soot in the tailpipe of this car after driving it nearly 2 years. Watch it fail emissions testing!!!
In my home state of Georgia, they don't have a state wide inspection program anymore. They just test emissions in the Metro Atlanta area and that's it. I think they gave up with all the rattle traps on the roads!!! Many years ago when it was in place, if you "knew" someone, you could get yourself a sticker for $20, and not even bring the car by!!!!
Mike
Come down to San Antonio, TX. I can point you to a few places on the southside who will get into your car, press your brakes, and pass you if your brake lights come on. :-)
