SCT help
Old Mar 21, 2006 | 07:31 PM
Menace's Avatar
Menace
Default SCT help
What is necessary to do when reflashing your computer? I just installed my C&L Intake and now I'm fiddling around with the SCT. I tried plugging it in but it won't read the codes. Am I supposed to disconnect the battery, or pull the fuses like it says? It says to pull the fuel pump and electric fan fuses, which I looked up and appear to be fuse #3 & #41 if I'm not mistaken? If anyone has some insight on this, would be appreciated, thanks,
-Menace.
Old Mar 21, 2006 | 08:50 PM
JJ_Stang's Avatar
JJ_Stang
Default RE: SCT help
When you connect the SCT tuner does it power on? If so you just have to scroll through the options. The first time you connect it to the car it should upload a copy of the factory settings to the Tuner.
Old Mar 21, 2006 | 09:19 PM
Stoenr's Avatar
Stoenr
mine didnt upload until i was in the flashing process....
But yeah if your trying just to read/clear codes, plug it in scroll/select i think its read DTC's or something like that.
Old Mar 21, 2006 | 11:56 PM
Menace's Avatar
Menace
It appears the LCD background came really light, so I had to darken it... Though I did try and scan down on it before this and it never seemed to open up the options to me. I did manage to tune it with the octane tune.. but that's the only tune I could find programmed... I guess that's all you get?
Old Mar 22, 2006 | 10:45 AM
JJ_Stang's Avatar
JJ_Stang
who did you buy it from? usually they come with three tunes.
12bigredstang
Sep 24, 2015 05:46 PM
12bigredstang
Sep 24, 2015 10:43 AM
03blackwidow
Sep 20, 2015 02:36 PM
kmad61
Tuner Central
Sep 18, 2015 05:02 PM
Sep 1, 2015 08:16 PM
